Liquid-gas separation
Old   August 14, 2006, 09:30
Default Liquid-gas separation
Easycad
Hi All! I need your advices on following multiphase problem. The problem is to model gas-liquid separation process taking place in a vessel. Liquid, containing both dissolved gases and bubble gases, enters the vessel, gets separated and then degassed liquid and gas are removed through two separate ducts. Both liquid and gas are multicomponent. The goal is determine if there is enough time for the phases to separate and how vessel geometry affects this. Temperature, pressure is const, heat of evaporation is negligible. As to me I have to use steady eulerian multiphase model, mass transfer should be taken into account through DEFINE_EXCHANGE_PROPERTY macro (I have a little understanding how to do it). Still dont know what to do with bubbles. So wating for your advices!
Old   August 15, 2006, 00:58
Default Re: Liquid-gas separation
Easycad
I think it is convenient to consider liquid as a single component, but gases not. Gases have different volatility so evaporate at different rates.
Old   August 29, 2006, 06:53
Albert S.
I have very similar problem, any advances? Would be nice if we work together.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Gas dissolution from liquid phase with CFX Roger Young CFX 2 May 6, 2008 07:37
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
