Flux+Temperature on a wall ?
Old   August 11, 2006, 05:48
Default Flux+Temperature on a wall ?
tanphi
I have a question : does anobody know if it's possible to have as boundary condition for a wall both temperature and heat flux ? (For example : a wall at 100°C with a heat flux of 500W/m² on it)
Thank you !
Old   August 11, 2006, 08:28
Default Re: Flux+Temperature on a wall ?
Raj Kiran Grandhi
I guess that would be too many constraints at the boundary.
It is like trying to specify the temperature, pressure and density of a gas at the same time. The moment you fix any two properties, the third is automatically fixed by the ideal gas equation. Likewise, for a given flow system, the moment you fix the wall temperature, the heat flux is fixed. Or if you specify the heat-flux, then the wall temperature becomes a derived quantity.
What is the physics behind what you are trying to simulate? Do you really have such a situation?
HTH, Raj Kiran
Old   August 11, 2006, 08:46
Albert F.
Hello all,
I'm in same situation, I have asked it at fluent support and they have said me that fluent does not support the two conditions. You have to impose one or the other and it is a little bit complicate because when you impose a heat flux you mean that all is radiation but is difficult to impose a quantity for the convection. The surface is also important in this cases because is not the same emiting 2000 W in a small or in a high surface. In fact it is more complicated that seems.
I'll try to find out the best choice, I think that there is a tutorial specialized in this terms.
Old   August 11, 2006, 09:40
tanphi
thank you for your answers
Raj, I think you're not right : you can have to specify heat flux and temperature at the same time on a wall, and to have the heat flux does not give automatically the temperature : For example if you want to know the temperature on the other side of the wall, to determine it you must have both temperature and flux.
Albert, I think I'll try to make a udf to force fluent to apply both conditions but I don't know if it will work.....
Old   August 11, 2006, 09:50
Albert F.
Ok tanphi, I'll look for information about this type of boundary conditions but I thing that an UDF would be the right way...
Old   August 17, 2006, 05:37
Albert F.
Look for this tutorial:
Thermal Model of Head Lamps using DO Radiation Model.
I think it can help.
Old   August 19, 2006, 09:06
Mark Russell
Conductive heat flux through the solid is driven by the temperature gradient across it. i.e. Qx = -KA dt/dx. And so the two conditions are intimately connected. Hence I wonder why you feel you need both conditions. Please provide details of the case you are studying.
Old   August 21, 2006, 02:28
Albert F.
I have a bulb that reamins at 900 ºC at the free stream but also emits 2000 W in radiation terms.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
assign both heat flux and temperature on wall qwerty753 FLUENT 2 July 14, 2010 08:09
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
WALL HEAT FLUX tommy CFX 0 December 20, 2005 12:42
