gambit: generate mesh from premeshed surfaces
Old   August 22, 2006, 10:43
Default gambit: generate mesh from premeshed surfaces
Ralf Schmidt
Hi!
I have a brick volume, that is premeshed on its 6 surfaces. On the 4 shell surfaces (the sides), the mesh has quad elements, the two opposite other surfaces (top and bottom) are meshed with tri elements (the same pattern).
Now, I want gambit to extent the tri elements from the top/bottom surface, forming in the volume wedge elements. The wedge elements should be build with help of the quad elements on the 4 sides.
This is like the copper scheme works, but I what it mannually.
How to to that???
Ralf
Old   August 23, 2006, 00:19
Default Re: gambit: generate mesh from premeshed surfaces
Gernot
I think the problem is that the tri mesh is not the same on both sides ( even when you set the same parameters ). mesh just one side and cooper it - should be no problem if you have map on the side faces.
Old   August 23, 2006, 06:43
sam
yes Gernot is right
3-d mesh gambit (cylinder within a cylinder) Jason ANSYS Meshing & Geometry 29 October 30, 2015 08:59
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Import surfaces with mesh from Gambit Peter FLUENT 3 July 19, 2007 18:00
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
