temperature limited - absolute pressure limited
Old   August 22, 2006, 02:20
Default temperature limited - absolute pressure limited
Asashi
Hi all
I,m simulating a bullet in the air (supersonic, euler). The first order stops at about 100 iterations, and the residuals jump over 1e+10 !
Here is a screenshot of the situation : http://img182.imageshack.us/img182/6...eenshotge6.png
The error message says : temperature limited to 5.000000e+03 in 1 cells on zone 2 ...and... absolute pressure limited to 1.000000e+00 in 1 cells on zone 2
Does anybody have any idea about how to fix it ??
Many thanks !!
Old   August 23, 2006, 04:17
Default Re: temperature limited - absolute pressure limite
saghir
solve-->controls-->limits ; and change the limite values. but it's bed solution you must adapte this cell or the grid
Old   March 31, 2011, 18:35
Default temperature limit to cell
cdf_user is on a distinguished road
Thanks that actually worked!!
still I am not sure why the temperature would be so high....
I have a cylinder which is receiving a heat flux of 15000 and it says temperature for 2345678 cell is 1.5e4 which is the same value as the flux. I am assuming this cell is near the wall.
cdf_user is offline   Reply With Quote
Old   July 18, 2014, 09:51
Default Hypersonic Flow Over Cylinder ( Temperature very high~280,000)
Mike
dreamchaser is on a distinguished road
I am modeling hypersonic flow (Mach 24) over a cylinder. I also faced the same problem where I am getting a temperature around 280,000 which does not make any sense.
I wonder if it is because I have assumed constant specific heats. But I feel something else is wrong here.
I have attached a picture of the temperature profile and boundary conditions. Any advice would be appreciated.
Thanks,
Dreamchaser
dreamchaser is offline   Reply With Quote
Manifold Absolute Pressure in Engine Simulations abminternet OpenFOAM 4 July 4, 2011 11:45
about large minus absolute pressure richard FLUENT 3 December 6, 2003 09:39
absolute pressure limited Boisson FLUENT 1 December 9, 2001 13:21
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
