Changing gambit file without change of case file??
Old   August 27, 2006, 03:08
Default Changing gambit file without change of case file??
Asghari
Hello all;
I change mesh within gambit and i want to preserve fluent settings such as material properties in same case file.
How is this possible? Please help me.
Thanks alot;
Old   August 27, 2006, 12:56
Default Re: Changing gambit file without change of case fi
cadaei
write the boundary conditions of original mesh using TUI. type: file/write-bc
then read in new mesh and read boundary conditions file using: file/read-bc
Old   August 28, 2006, 13:48
Asghari
Ok;
Thank you very much from your help!!
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
