September 2, 2006, 19:02 |
Engine Plumbing in Gambit
I'm trying to model an intake plenum and runners for a 4 cylinder engine. I've been able to model T-junctions by joining two perpendicular cylinders, but I cannot model Y-junctions successfully. The Y-junctions are supposed to look like 2-to-1 collectors. I have tried joining two converging frustums to a cylinder, but this hasn't worked.
Also, I able to sweep a circle along a curve to create bent tubing. However, I want to create bent tubing with a decreasing cross sectional area. It won't let me revolve a curve around another curve. Is this possible with Gambit? |
meshing of two-stroke engine in gambit | ravi | FLUENT | 2 | January 18, 2012 01:14 |
Turbofan engine model meshing in gambit | vincentryan | ANSYS Meshing & Geometry | 9 | July 27, 2010 03:09 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
gambit for greating engine geometry | sadoun | FLUENT | 2 | May 28, 2006 15:55 |
