NEGATIVE ABSOLUTE PRESSURE IN FLUENT
Old   September 28, 2006, 23:48
Default NEGATIVE ABSOLUTE PRESSURE IN FLUENT
vitmalin
Greetings everyone! I've got a problem performing simulation of axial water pump: incompressible water, 10000 rpm, pressure inlet, presure outlet, two domains rotor and stator coupled via mixing plane. The matter is that converged solution gives very unusual result: negative absolute pressure at inlet about -100 atm, wich gradualy rises up to 10 atm at pressure outlet. How could negative pressure occur in solver if it is predefined and climed to be positive? Please help me find out the answer on this question!!!!
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
negative static pressure Selo melo FLUENT 5 December 18, 2006 09:30
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
about large minus absolute pressure richard FLUENT 3 December 6, 2003 09:39
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
