Problem in Gambit
Old   September 5, 2006, 05:27
Default Problem in Gambit
Francisco
Hello Everybody
I'm realy do not get it why gambit can't connect tow volums with different mesh size. I know now that I can connect them in Fluent as interfaces, but in connsequence I will have to connect 100's of interfaces because I copy the basic geometry a few times.
Does anyone have an idea how to connect the volumes in another way in Gambit itself, so I do not have to work on interfaces in Fluent.
Thank you
Regards
Francisco
Old   September 5, 2006, 07:46
Default Re: Problem in Gambit
Jason
You can't. Non-conformal interfaces are defined within Fluent.
If you have multiple cases, you may be able to setup the first one, and then file/write-bc and then file/read-bc for the new one and that MAY set the interfaces for you.
Another option would be writing a journal that sets up the interfaces for you, but I don't know what the syntax would be for that. You could record what you're doing and then try copying that for the other interfaces. You'll have to look up how to reference face names in a journal, or you'll have to figure out what all of the face IDs are.
Good luck, Jason
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 02:33
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam Rachid BANNARI (Bannari) OpenFOAM Meshing & Mesh Conversion 25 September 11, 2011 07:58
Gambit installation problem Panos FLUENT 4 March 5, 2009 22:44
Problem meshing with Gambit Adrian FLUENT 8 October 7, 2008 08:39
Startup Problem in Gambit 2.2 with WindowXP Win Win Maw FLUENT 3 January 25, 2006 11:09
