journal file
Old   September 5, 2006, 05:19
Default journal file
seeta
hi am finding problem with writing auto save after 200 iterations and simulataneously i want to write monitors in journal file which has writen for running fluent in batch mode. for understanding i am attaching the example journal file here.. can any body help me out in this context.......
file
read-case-data test.cas
/solve
iterate 2000
quit
/file
write-case-data
y
quit quit quit quit quit quit quit quit quit
exit
Old   September 5, 2006, 21:36
Default Re: journal file
zxaar
file auto-save overwrite-existing-files n file auto-save case-frequency 10 file auto-save data-frequency 10 file auto-save root-name "caseName"
this is what I use and it works fine. Try it.
Old   September 6, 2006, 05:28
SEETA
hi Zxaar, thank you very much. I wil try for that
Old   September 6, 2006, 05:49
SEETA
if i want to write the velocity monitors also in my journal file. is it possible to write ....
Old   September 6, 2006, 08:50
zxaar
what do u mean by velocity monitors ???
Old   September 7, 2006, 02:03
seeta
like force monitors. i want to monitor the velcity at differnet points in my domain.if you go solve->monitors->surface-> it will open one window in that you can monitor any parameter which you want.Here i am monitoring the streamwise velocity for every time step. i think u understand what i am saying.
Old   September 8, 2006, 04:02
nan
Hi.
maybe you can use this if I don't misunderstand what you wrote.
solve mon surf set [monitorname] vel-mag [surfacenames] () no no yes [filename] "Area-Weighted Average"
hope it helps.
Journal file to automate a time step change Damien_CFD FLUENT 0 August 2, 2011 07:05
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
Problem with Boundary Conditions using a journal file T.S. FLUENT 3 July 27, 2009 08:31
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
