October 9, 2006, 02:13 |
size function
Dear Sirs,
I have a problem with size function and meshing. I am having a complcated 2D geometry where the space to mesh is around 0.4 mm in some part whereas it has around 6 mm in some part. So, I used (Fized) Size function with Start size = 0.0002 m and End with 0.001 m with growth of 1.1. I connected all the edge with the face as attachment. The geometry doesnt accept meshing, with this size function. It runs but after longgg time it denies to mesh. Can anyone tell me why it happened & what has to be done now in order to mesh considering the small space as welk as the larger space. Thanks in advance and kind regards, Rana |
October 9, 2006, 18:26 |
Re: size function
Hi Rana,
Whats the error gambit spits out. If possible mail your geometry to me at aparajits@vipac.com.au Thanks Regards Rajit |
October 10, 2006, 02:28 |
Re: size function
Hi Rajit,
The problem with my geometry is with the narrow channel which i have to mesh. the channel is 0.4 mm in width. as i have to mesh this extremely narrow space as well as broad space; i used size function. Start = 0.0002 m with growth of 1.1 and ends = 0.005 m. i used fixed size function with edges as source and the face (i had one face) as attachment. although the no. of cells were manageable, i foud equiangle skewness of this 2D geometry is 0.95 - which is definitely unaccepable. now pls suggest me how to mesh with acceptable skewness. kind regards rana |
Gambit size function query | Jon | FLUENT | 7 | December 21, 2011 04:02 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Size function problem | Joren | ANSYS Meshing & Geometry | 2 | April 9, 2010 07:06 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
