Impeller mesh size (Unstructered)
Old   November 15, 2006, 12:03
Default Impeller mesh size (Unstructered)
Abdul
Hai all,
Can anyone please recommend me to know the rough size of the mesh required to model a frozen impeller(alone) with 11 vanes having 1020mm outer diameter.
Thanks in advance Abdul
Old   November 16, 2006, 04:21
Default Re: Impeller mesh size (Unstructered)
Sastry
hai
did you used turbo tool or not, if not pls try turbo tool,for proper meshing model must be fine with out any distortions,if u used turbo tool check with changing the inlet and outlet virtual vertices
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
unstructure mesh size control near to wall using gambit lalit kumar FLUENT 4 July 6, 2010 15:13
Gambit Unstructed (Tet) Mesh - size control newbie FLUENT 3 August 26, 2008 11:38
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
