need definition of the role of journal in fluent
Old   October 15, 2006, 04:22
Default need definition of the role of journal in fluent
ali
i need definition and the role of journal in fluent
note:the journal in gambit is a lotof of instructions for to create geometry, meshing..... best regards
Old   October 15, 2006, 12:41
Default Re: need definition of the role of journal in flue
Ralf Schmidt
Hi!
have a look at
http://www.cfd-online.com/Wiki/Fluen...TUI.29_Related
What is a journal file?
A journal file is a series of TUI commands stored in a text file. The file can be written in a text editor or generated by Fluent as a transcript of the commands given to Fluent during your session. A journal file generated by Fluent will include any GUI operations (in a TUI form, though). This is quite useful if you have a series of tasks that you need to execute, as it provides a shortcut. To record a journal file, start recording with File -> Write -> Start Journal..., perform whatever tasks you need, and then stop recording with File -> Write -> Stop Journal...
best wishes
Ralf
Definition of swirl fraction for hollow cone injection in Fluent launchpad FLUENT 0 June 30, 2011 03:22
running a journal file in Parallel FLUENT novice FLUENT 0 June 15, 2010 04:19
Re FLuent Journal harry FLUENT 2 May 12, 2010 01:03
How to simulate a dynamically loaded journal bearing with Fluent? okiro FLUENT 0 April 7, 2010 21:16
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
