Plotting in fluent
Old   November 30, 2006, 14:58
Default Plotting in fluent
Meenu
Hi
I want to plot two dimensionless numbers in fluent. these numbers are not defined in fluent, these are my numbers like a temperature ratio and a radius ratio. How can I do that? Do I need to define my ratio somewhere,if yes then where n how??
Cheers!!
Old   November 30, 2006, 15:23
Default Re: Plotting in fluent
Jason
Define a custom field function (Define->Custom Field Function)
Best of luck, Jason
Old   November 30, 2006, 17:57
Meenu
hello,
Thanks Jason. Have another problem..I'm not getting 'temperature' in the field functions,I'm getting pressure,density and other functions but not temerature.How can I get that??
cheers
Old   December 1, 2006, 05:17
zxaar
if you go custom field functions by fluent tui, you will see there is an option list variables, this will list all the variables you can use in custom field functions, (have you enabled enery eqn, by the way ) )
Old   December 1, 2006, 07:15
Meenu
hey..thanks yes my enery equation was enabled, i restarted fluent and it worked... I'm able to write and save the function but now when i go to XY plot and through load file try to load my function it says function not found . do i need to patch my functions?
cheers
Old   December 1, 2006, 08:39
Jason
After you create a custom field function it shows up as a variable in the drop down menus. I.E. instead of selecting an XY plot of Pressure-Static Pressure select an XY Plot of Custom Field Functions-<whatever you named your function>... CFF shows up at the very top of the main variable list, so you may have to scroll up in the drop down box.
Hope this helps, and good luck, Jason
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
