hi evereybody
I want to calculate the drag coefficient and lift coefficient on an airfoil (2d wing).When I go to Report>>Forces it shows the pressure coeficcient, total force and pressure force, which is something that I don't need. Also if i request to calculate the area of the wing it gives 0.20426972m2.On the reference values the area is 1.If I change the are here doesn't do anything... What should I do? |
Hi Pedro, I'm working on such a field like yours..I'm studing the Cl and Cd curve of 2D profiles dipending on different angle of attack (from 0 to 90)...I suggest you not to take care about the references value but just to go in Solver>>forces>>and set Cl and Cd, select the option PRINT and after the simulation is converged ( it depends on the criteria you require)you can see the value of Cd and Cl..
I suggest you also to follow the fluent tutorial file about airfoil. If you want we can keep in contact to share ideas and result |
lift & drag coefficient on airfoil | n. natik | FLUENT | 8 | March 31, 2015 19:02 |
lift and drag coefficients around a ground vehicle | Pedro | CFX | 3 | September 5, 2012 18:31 |
how to set lift and drag coefficients in force mon | alagesanj | FLUENT | 0 | November 16, 2008 20:47 |
Lift and Drag Coefficients Reliability | Luis | FLUENT | 2 | December 27, 2005 14:45 |
Airfoil Lift and Drag | Dr. Laith K. Abbas | Main CFD Forum | 8 | July 2, 2005 03:32 |
