microfluidic mixing
Old   January 6, 2007, 17:56
Default microfluidic mixing
Lukasz Mosakowski
Hello, I'm working on the simulation of mixing in a microchannel. Given that the Reynolds number is very low, near zero, how do I simulate the degree of mixing that occurs a)by diffusion and b)by the convergence of two liquids at right angles? How should I appreciate such a simulation? Any help would be much appreciated, thank you in advance.
Old   January 7, 2007, 20:29
Default Re: microfluidic mixing
Lukasz Mosakowski
by appreciate i mean approach, sorry everyone
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 14:31
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 09:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
turbine efficiencies, conservation rules across mixing planes Jonathan FLUENT 0 October 4, 2010 09:04
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
