divergence detected in AMG solver: momentum
Like Tree3Likes
Old   January 9, 2007, 23:36
Default divergence detected in AMG solver: momentum
sudhakar
Hello Friends, i am working on shell and tube heat exchanger using seggregated solver and laminar,and alsoheat exchanger models My simulation today give me an error message:"Divergence detected in AMG solver:x momentum Error object)
I have no idea what it means and how to get around it.
I like to be helped by members of the forum.
With advanced thanks
sudhakar
Old   January 10, 2007, 11:42
Default Re: divergence detected in AMG solver: momentum
Wang
I have same problem.
Old   January 10, 2007, 12:02
KP
Tighten your under relaxation factors and then run. For instnace check on momemtum under relaxation factors now say its 0.5 tighten it to 0.1. Then this error should go away. However doing this increase your tun time. KP
Old   January 11, 2007, 04:53
sudhakar
I tried from urf from .7 to .001 .but i could not get. in my problem no of cells are more than 8 lakh. my problem is shell and tube heat exchanger in 3 dimensional using seggregated solver.previous i solved same problem with out headers .but now i inserted headers now i got above problem divergence detected in AMG solver: momentum
please help me to solve this problem
Old   January 12, 2007, 06:56
Wang
I used coupled solver instead of seggregated one. Then reduced urf. The case is working.
Old   August 7, 2010, 05:26
Default divergance
ahmad
almostafa67 is on a distinguished road
hi everybody...
i have same problem,i changed urf from 0.5 to 0.05 but again error message showed up!
dear wang i did not understand ur method please explain more and help me out.
thank u in advance for any help provided
almostafa67 is offline   Reply With Quote
Old   May 5, 2011, 18:14
Nick Smith
mrnsmith is on a distinguished road
So by coupled I think he means under the solutions methods tab and under Pressure-Velocity coupling Scheme to change it to coupled. And then urf means Under relaxation Factors in the solution controls tab.
However I am having the same divergence in x-momentum error and this isnt working either!
mrnsmith is offline   Reply With Quote
Old   March 11, 2012, 15:25
zainab p
zeybi1604 is on a distinguished road
Hello. i am doing a multiphase simulation in a packed bed using the mixture model. the volume fraction used was 0.5316.i keep getting the error message "divergence detected in AMG solver: x-momentum" for all the different solvers used and i even changed the under relaxation factors. i really have no idea how to proceed with this simulation!plzz help!thank u.
zeybi1604 is offline   Reply With Quote
Old   July 1, 2013, 03:27
Unhappy mine too
zfa91 is on a distinguished road
Dear friends,
I'm having same problem , as i ve checked the meshing was ok. but, x-axis still not 0. how to state the axis as needed plus how you re sure your boundary condition is correct?
This x-momentum problem make me stuck forever.
Help me
Triality likes this.
zfa91 is offline   Reply With Quote
Old   July 11, 2013, 01:04
zainab p
to check whether your boundary conditions are properly defined just have a look at your values obtained from the velocity vector profiles.you should generally have an idea where should be the inflow or outflow this can also help you to check your suitable conditions.
which version of fluent are you using?
i got this proble because i was using an old version of fluent.maybe you should update yours.
my problem on the x-momentum was never solved.
try the different relaxation factors and your conditions setings.
goodluck!
Old   September 21, 2013, 10:40
Default Solution for Error : Divergence detected in AMG solver: x-momentum
  #11
Ashok Raj
ashok is on a distinguished road
This error is due to large mesh element size. If the mesh was created in units other than metre the mesh has to be scaled. Go to problem setup/general/mesh/scale and check on the specify scaling factors.
ashok is offline   Reply With Quote
Old   November 28, 2013, 09:17
Dimitris Romanas
Volumeoffluid is on a distinguished road
Hi all,
i have this error...
# Divergence detected in AMG solver: x-momentum -> Increasing relaxation sweeps!
Error: Divergence detected in AMG solver: x-momentum
Error Object: #f
May i must increase from the solution controls---advanced---max fine relaxation ????
What shall i do??
Thank you in advance!
Volumeoffluid is offline   Reply With Quote
Old   November 28, 2013, 10:34
ASHRAF ALFANDI
ashraf88 is on a distinguished road
Hi, I had the same problem before,
1. check your mesh, make finer
2. check the initial conditions, usually this kind of errors appears because of wrong values of the initial conditions
3. good luck
ashraf88 is offline   Reply With Quote
Old   November 29, 2013, 05:44
Dimitris Romanas
3. good luck
Hi dude,
I have still the same problem...Maybe i should chande the under relaxation factors and scale better the mesh...pfff..
Old   November 29, 2013, 13:45
Smile
  #15
ASHRAF ALFANDI
Originally Posted by Volumeoffluid View Post
Hi dude,
try to make the energy under relaxation factor 0.995
I am sure that eventually you will solve the problem.
good luck
Old   November 30, 2013, 08:13
Zaktatir is on a distinguished road
the reason of the divergence is manifold: without any setting you get only speculative tips nothing more! Either you post your settings or you contact you Ansys support if you have a legal license.
-Boundary Conditions
-Velocity Profiles
-Numerical Setup
The fact that you give small URS til 0,001 and we still get failure that means your setup is wrong
Zaktatir is offline   Reply With Quote
Old   December 3, 2013, 10:12
Dimitris Romanas
-Velocity Profiles
-Numerical Setup
Hi Zaktatir,
so do you want to send you my settings-project to take a look?
My email is jimromanas@hotmail.com
Old   December 16, 2013, 00:29
sachin kumar
sachin07essence is on a distinguished road
same problem is there with me
sachin07essence is offline   Reply With Quote
Old   January 12, 2014, 16:28
Default Minor problem in geometry
  #19
Mahdi Torabi Asr
mahditorabiasr is on a distinguished road
Any minor problem in geometry also can lead to such a error.
In my case, I used DesignModeler and I got following warning after using FaceSplit tool between modeling.
"Warning: At least one tool geometry selection did not result in a split"
Although the Model status was Ready(but in yellow color!!) and I jumped to Setup, that error returned.
mahditorabiasr is offline   Reply With Quote
Old   March 28, 2014, 10:00
samir
samir_cfd is on a distinguished road
Send a message via MSN to samir_cfd Send a message via Skype™ to samir_cfd
Good day
I have a problem when I am simulate unsteady flow around a propeller, divergence detected in amg solver. x momentum, I reduce the URF but is the same problem
samir_cfd is offline   Reply With Quote
Error: Divergence detected in AMG solver siri FLUENT 8 March 12, 2018 17:08
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Divergence detected AMG solver error Rub Nawaz Khalid FLUENT 2 August 14, 2010 11:01
ERROR: divergence detected in AMG solver black mamba Main CFD Forum 0 April 19, 2010 15:15
divergence detected in AMG solver. Babu FLUENT 3 March 4, 2005 03:08
