January 3, 2007, 08:32 |
Problem with interpreted function
Hello I want to ask for help. Problem is: Every time I want to intepret function error occur. for example:
Error: D:\praca dyplomowa\odlewanie_cisnieniowe\fluent\udfexample. c: line 1: parse error. I was trying different functions, I was copied function from fluent udf help, always occur the same error "line 1: parse error" nevertheless I am convinced that code is valid. I am using windos Xp Fluent 6.2.16 I will aprreciate whatever help from you. Sorry for my english |
January 3, 2007, 08:46 |
Re: Problem with interpreted function
I found answer on this forum after I posted my notice. I didn't see it earlier.
Thanks |
January 10, 2007, 13:02 |
Probably the problem is the name of the directory in which the .c file is, copying it in c:\ all works fine...
LiencubiclowRemodel | nzy102 | OpenFOAM Bugs | 14 | January 10, 2012 08:53 |
user-defined function problem | wlt_1985 | FLUENT | 0 | April 18, 2011 07:02 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
