UDF help needed~
Old   January 15, 2007, 23:35
Default UDF help needed~
Nelly
Hi all,
I'm now doing a project that require me to define a velocity profile of fluid flow via a UDF. Can I know which program can I use to compile?
Due to "udf.h" defined in the beginning, is it impossible to compile the source code using a standard C compiler?
Many thanks in advance!!
Old   January 16, 2007, 05:11
Default Re: UDF help needed~
ammi
hi dont compile it in c compiler. save it only. then make userdefined ->function -> interpreted then broows the function and interprete if any error it will display their , then make correct and again interprete
Old   January 17, 2007, 05:03
Nelly
I have got it! Thanks!!!
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
