January 19, 2007, 17:20 |
material property
Hi, How implement to Fluent material property as a function pressure?? for example: viscosity? How write udf? The same in case when viscosity is a function a temperature??
Thanks for help Tomik. |
January 20, 2007, 00:20 |
Re: material property
Use the macro DEFINE_PROPERTY, one example of temperature dependent viscosity is given in the udf manual.
get the macro for pressure; calculate the viscosity and return the value; Hook the udf at correct position. Sujith |
material property | wlt_1985 | FLUENT | 4 | October 29, 2010 06:28 |
Liquefied natural gas_LNG material property help! | songxguan | FLUENT | 0 | November 14, 2008 05:50 |
material property problem | llnudt | FLUENT | 0 | November 23, 2006 10:02 |
