How to model natural convection
Old   January 20, 2007, 12:10
Default How to model natural convection
Ken Adams
Hi all,
I'm modeling a heatsink with several heat sources distributed on it. The whole system is exposed to air and cooled by natural convection. But could anyone tell me how to specify the space surrounding the system as air/fluid in Fluent/Gambit and how to set parameters for natural convection?
Thank you,
Ken
Old   January 21, 2007, 13:56
Default Re: How to model natural convection
Suijth
You can give the heat transfer coeff as a boundary condition to wall, if you have a wall boundary and heat convection is taking place over it.
Else you can model the entire domain with surroundings and fluent will calculate the heat transfer.
Old   January 21, 2007, 17:35
Ken Adams
Thank you, Suijth. But could you explain more on the last sentence?
Old   January 23, 2007, 12:23
Sujith
You have to make two zones in the domain, fluid and solid. At the interface btween the two, fluent will make it a coupled wall boundary condition. Only thermal eqns will be solved in the Solid. Now you can model the natural convection over this wall.
there is one tutorial available at fluentusers.com, tutorial 5 , which solves a problem with natural convection. You may need to use bossenisque parameters for good results in natural convection.
Sujith
Old   January 23, 2007, 15:14
Ken Adams
Thank you very much.
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
natural convection Boundary Conditions saba_saeb Main CFD Forum 2 December 12, 2010 18:41
Natural Convection Boundary Conditions, tips or advise needed ! Logan Page ANSYS 0 September 27, 2010 18:44
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 04:22
Natural convection. Air properties Cristina FLUENT 3 March 24, 2007 08:23
