urgent help too many VOF subtime steps error
Old   January 22, 2007, 19:06
Default urgent help too many VOF subtime steps error
sudheer
Hello
I am trying to model the flow of a liquid partilce with high density and viscosity suspended in water in a 3D-bend using VOF method. When I run the simulation without the particle my velocity field seems to converge, but when I adapt a spherical region with a specied radius and run the VOF solver I get an error " too many VOF sub-time steps. the velocity is probably diverging. Please reduce the time steps if necessary" . I even tried reducing the time step size. I'm pretty sure that my grid is fine. I would greatly appreciate if you can help me out. Thank you very much
Old   January 24, 2007, 00:16
Default Re: urgent help too many VOF subtime steps error
Muke
Are you trying to mark a region with adapt option, for the purpose of patching/initialisation.
I guess instead of clikcing on mark option you might have clicked on adapt.this refines the grid in the region you have defined and so the error. You can see the refined grid, once you adapt and redisplay the grid.
polynomial thermophysical properties II sebastian OpenFOAM Running, Solving & CFD 54 November 21, 2019 07:12
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 06:12
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
