Convergence is valid or not (with reversed flow)?
Old   January 29, 2007, 11:42
Default Convergence is valid or not (with reversed flow)?
Chesers
I wonder that:
The convergence with the message "reversed flow in 6 faces on outflow" is a valid convergence or not?
In other words, when it occurs, shoud we accept it or try to re-run to overcome it?
Old   January 29, 2007, 23:47
Default Re: Convergence is valid or not (with reversed flo
pinks
Reverse flow is problem dependent. if you have your outlet at such a position that there are vortex in your flow physics, you will surely get reverse flow in your simulation. In other words, consider flow over a cylinder and now you ahve your outlet in the wake zone of the cylinder, then you will get reverse flow. You can increase your outlet location, though this is conditional. If you coudl tell your geometry, the situation would be more clear to comment.
Flow through porous medium using CFX: lack of convergence Chander CFX 3 July 23, 2014 06:32
something about the reversed flow zjbwow FLUENT 0 April 1, 2009 23:28
Problem with Convergence at high flow rates Syed Siemens 1 April 10, 2007 15:18
2 Inlet Pres BC's and Out Mass Flow - Convergence SN Siemens 0 July 19, 2006 09:12
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
