Getting steady-state solution for turbulent model?
Old   February 23, 2007, 17:14
Default Getting steady-state solution for turbulent model?
Kwontona
To get a steady-state solution for two-phase turbulent model under Eulerian model framework, usally there are several logical ways which I have tried:
Method_01: get firstly the laminar flow steady-state solution; and then switch to turbulence modeling;
Method_02: perform firstly unsteady-state simulation for very long time; then switch "UNSTAEDY" to "STEADY".
However, it is found that the above methods do not work for my simulation system. So, how to capture the steady-state solution for the two-phase turbulence model (E-E approach)?
Can anyone give some ideas fot this? Thanks in advance.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
Using turbulence model for steady state analysis Terry FLUENT 7 February 28, 2001 07:03
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
