Error when meshing
Old   February 8, 2007, 12:46
Default Error when meshing
rayy
Please help me. I m a new user.
I used Gambit to construct a basic cylinder which will represent a gasifier. Nearly at the bottom of the cylinder, I construct 9 nos. of nozzles by using cylinder also. Those nozzles located circumferential the gasifier. Then I substract those volumes so that I can get a gasifier with penetrated holes(nozzles). The problem is error message came out:
ERROR: Imprinting of projection edges failed when meshing volume volume.1. Check to insure that source faces are correct.
Please tell what went wrong?
By the way, how we can know that the meshing scheme we choose is appropriate for our model? On what basis we are supposed to choose the scheme?
Thanks in advance.
rayy
Old   February 9, 2007, 00:40
Default Re: Error when meshing
chanukyareddy
ok why donot try for tet\hybrid....( tet ).u can get any type mesh byusing this scheme...and if it is not possible then go for reduce interval size and try....
Old   February 9, 2007, 14:34
rayy
Thanks Chanukyareddy...it works!! I used tet/hybrid and reduce the interval size.
By the way, i got another question...my model consists of 3 part of cylinder with different diameter. Then I union my model and become 1 volume. Since the middle part i only can mesh it with tet/hybrid and the other 2 parts I use Hex,...does it mean that I shouldn't union my model but rather let it be 3 separated part with different meshing scheme?
If we use different scheme and different interval size on 1 model(consists of 3 parts?, does it affect the quality/accuracy of my simulation?
Thanks
rayy
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
