compilation techniqes
Old   February 9, 2007, 05:42
Default compilation techniqes
brusly
hi cfdiens
does any one know how to create a files that require to compile the udf.(not header files)libudf...etc
thanks in advance
Old   February 11, 2007, 06:54
Default Re: compilation techniqes
renuka
actually what u want to know be clear . U CAN udf in C taking the help of help file. it should BE COMPILE OR INTERPRETE to link with fluent. u just write udf in c and open fluent and go define ->userdefine ->function ->interpreted/compiled it may help u
Old   February 11, 2007, 23:09
brusly
thaks for your reply
i have a c program.when i open the compile option there are two columns,one is source another is header files.for the source i can select the c source but wat about the headerfile? nothing is visible.
thank you
Old   February 11, 2007, 23:29
renuka
hi No need to go for the header file. JUST LEAVE IT AND PROCEED OK ALL THE BEST
Old   February 12, 2007, 03:25
brusly
hi i did the same but it shows like this
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
thank u
Old   February 12, 2007, 03:52
renuka
have u installed VC++ in ur sysyem properly ?
Old   February 12, 2007, 04:02
brusly
ya i have installed,the case and data files are in the same directory.i am using fluent 6.1 version will this make any difference?
thank u
Old   February 12, 2007, 04:28
renuka
send ur udf , case data file to me if possible, i will check it here
Old   February 12, 2007, 05:22
brusly
ok thank u
Old   February 12, 2007, 05:36
renuka
i got ur case and data send ur UDF (only) once again . it should be in .c form
Old   February 12, 2007, 05:51
  #11
brusly
got it
Old   February 12, 2007, 06:04
  #12
brusly
u got the new one
  #13
renuka
hi in my system same problem in coming . i had compiled udf in my system for 2d problem but not 3d one
i think their may some problem in ur udf or their may something different for 3d i dont know
Old   February 12, 2007, 06:07
  #14
brusly
i have tried in 2d also...i thing the fluent 6.1 dont have the option to use the define_mass_transfer macro... any way thanks for suggestion
r u srenath reddy
thank u
errors during compilation and installation of OpenFOAM-1.7.x on Ubuntu 10.04 ftec OpenFOAM Installation 7 February 23, 2011 06:07
Compilation Order and Single Precision Issues gocarts OpenFOAM Bugs 1 October 14, 2009 17:19
Compilation Error when running Tutorial 2.4 zhihuali Siemens 7 April 1, 2008 07:34
Compilation error with uparm.f Raghu Siemens 2 May 30, 2007 02:09
Compilation Error.... Arnab Siemens 4 September 12, 2004 15:54
