Text Command for Monitors
Old   February 27, 2007, 10:33
Default Text Command for Monitors
ozgur
Hi All,
When defining surface or volume monitors by text command: /solve/monitors/surface/ set-monitor
there is no option to set X-Axis that you would normally see in Define Monitor window in GUI. I checked also the text commands list, and it is not there.
The only workaround i could find is to open the case file in GUI, manually set X-Axis to say 'time step',and save the case file. Since I'm performing batch simulations without GUI and define all monitors in the script file, you can imagine that it's quite annoying to open and resave each and every simulation case files in GUI, before starting the calculations.
Does anyone knows somehow a command to set X-Axis in monitors?
Thanks in advance. ozgur
Old   November 20, 2009, 20:41
Dagnew
FIJU is on a distinguished road
Hi, I hear you man.
Here is how it works, once you reach at monitor frequency [1] put it greater than 1, say 5 then you will be asked for time step [no]....put yes --> x-axis> choose flow-time or iter or time-step. Hope this will help you
Cheers !
Ager
Originally Posted by ozgur
;139590
Hi All,
FIJU is offline   Reply With Quote
Command to render text output from each mesh block pgopalak FLOW-3D 3 October 2, 2009 18:32
Using text commands in FLUENT shankara.2 FLUENT 2 July 20, 2009 14:18
DPM Particle tracks summary text input Rajesh Gutti FLUENT 1 October 17, 2008 02:29
Saving velocity contours to a text file Craig Johansen FLUENT 1 March 6, 2007 19:07
rsm,K-epsilon models, donating text on turbulence francisco saldarriaga CFD-Wiki 1 May 19, 2006 04:54
