how to set initial pressure in a closed system |
March 12, 2007, 06:43 |
hi
I am modelling a refrigeration system consisting of compressor , aftercooler, regenerator ,cold and hot end heat exchanger connecting tube and reservoir. This is a complete closed system.I want to set initial charging pressure of the whole system at 50 bar.Means when time t=0 whole system is at 50 bar.When reciprocating compressor piston moves back and throgg the compression and expanssion of gas takes place. Please help how to set this initial pressure. Y.P. Banjare |
March 12, 2007, 11:34 |
Re: how to set initial pressure in a closed system
Did you try initializing your flow field? Solve->Initialize-> Initialize -Phil
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Negative value of k causing simulation to stop | velan | OpenFOAM Running, Solving & CFD | 1 | October 17, 2008 05:36 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
