MRF IN FLUENT HELP
Old   April 4, 2007, 13:08
Default MRF IN FLUENT HELP
H.A.S
I have a brick where there is a wind turbine inside it , i substracted the two volumes and meshed . When i was working on Fluent , I choose the following boundaries : Velocity inlet , Pressure outlet , and all other faces are indicated as walls . is it right ?? . I am working on Multiple reference frame ;
any advice ,
Regards
Old   April 4, 2007, 23:45
Default Re: MRF IN FLUENT HELP
sam
Yes it seems right.
what about the periodic boundary
regards
Old   April 5, 2007, 01:30
H.A.S
Thanks for your reply ,
I didnt take into account any periodic boundary ? Should I ? if yes , what are the best periodic boundaries that i should take ? I have a Vertical Axis wind turbine .
Thanks in advance , Regards
Old   April 5, 2007, 23:33
sam
Are you modeling all blades in your case. If you want to model only one then you need to use the periodic condtion. and as far as periodic condition is concernt, you just need to define it, no need to enter any thing else (except the type of periodicy i.e transtational or rotational).
Old   April 6, 2007, 03:54
H.A.S
yes , i am modeling all the blades (3 blades) , i amworking on Darius model . I read about the periodic condition in the documentation , but u said that it is applicable only in 1 blade ?
Old   April 9, 2007, 01:12
sam
yes if you want to model only one blade (i.e one third of your fluid domain). this will redcude your computational cost e.g if you have .3 million nodes in 3 blade passage then by solving one blade passage (periodic boundary condition enforced) you have only 0.1 million nodes.
But it is not compulsory to do so(but most of the people do so).
you should also go to fluent web site and there is one example related to your problem type (fluent newsletter)
thanks
Old   April 9, 2007, 08:32
H.A.S
Thanks for your help , the newsletter seems important , i got it and sign up with it ; Thanks H.A.S
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
