How get Species Molecular Weight in UDF
Old   April 14, 2007, 02:21
Default How get Species Molecular Weight in UDF
hesam
Hi I want to write a UDF in witch I must use Species Molecular Weights (I activated species transport on Defin>Species panel). How i can get these properties in my udf. I try to use mixture_species_loop but the following error has ocdcured: ***** structure reference not implemented ******* Is there another way?? Thanks!
Old   April 14, 2007, 18:55
Default iron rusting
Ahmed
Hi, I used multiphase flow liquid liquid phase, Naphtha-water flow. Oxygen present in bulk, chemical reaction occurred at the pipe walls {2Fe + 1.5 O2 + 3 H2O --- 2Fe(OH)3 } how define this reaction and species in fluent? the oxygen consdered species transfer from bulk to wall.
anyone help me.
How to access species molecular weight in UDFs Ellen FLUENT 3 June 2, 2019 19:55
UDF species equations louiza FLUENT 4 March 10, 2010 01:20
PB: Saving mass fraction of species on two points with an udf biget.a FLUENT 2 July 23, 2009 03:06
Pressure and molecular weight ? Jane FLUENT 0 January 2, 2009 04:17
UDF reading species data of pdf simulations Jamiro FLUENT 0 June 20, 2001 17:15
