Macro for initialising the derivative to zero |
May 3, 2007, 06:29 |
I want to initialise the first order differential of a uds to zero.
i have tried using DEFINE_INIT, DEFINE_PROFILE. but it does not iterate at all, even though it gets compiled. HELP. |
May 3, 2007, 09:03 |
Re: Macro for initialising the derivative to zero
make sure you have defined a uds in the fluent menus before you read the udf into fluent.
May 4, 2007, 01:27 |
I have defined the uds in the fluent menus (Define--> UDF-----> Scalars . Plz help asap. Thanks
May 4, 2007, 08:54 |
try defining user defined memory also, you may have used it in your udf. Otherwise you'd need to post the udf for people to have a look at.
May 6, 2007, 00:04 |
Thanks, I wll try this
Macro Problem!!! | eRzBeNgEl | STAR-CCM+ | 3 | August 9, 2011 02:04 |
Macro Trouble -Winows Explorer Crashes with Macro | Martin Castillo | FLUENT | 1 | July 25, 2007 04:18 |
Macro problem | cfddummy | Siemens | 1 | April 9, 2007 12:37 |
macro not function! | guang ai | Siemens | 0 | July 25, 2004 18:53 |
Call a macro from a macro | Flav | Siemens | 2 | July 1, 2004 05:42 |
