problem in UDF
Old   May 4, 2007, 02:55
Default problem in UDF
sudhir
i tried to write program for UDF in C. i used udf.h as header file but my computer is showing error msg that "header file does not exist". how to add udf header file in my computer?
Old   May 4, 2007, 04:55
Default Re: problem in UDF
saghir
hi, you must put all the files on the same work file
Old   May 4, 2007, 09:08
Phil
the header file udf.h can be found buried within the fluent directory, I think in one of the lib folders.
I don't know the exact rules but to be safe I always try and have header_file,pdf,udf,mesh,thermodynamic_database,et c,etc, in the same directory.
It's best to copy files rather than move them.
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
