May 7, 2007, 23:10 |
turbulent viscosity ratio
What is the range of turbulent viscosity ratio in inlet of turbomachinery?Thank you!
May 10, 2007, 03:50 |
Re: turbulent viscosity ratio
Read CFD-Wiki. There is something about this written there. What eddy viscosity ratio you have depens on which component you are interested in. It can range from say 10 for a fan rotor to say 10000 for the inlet to an HP turbine. In general I would not recommend using this as an inlet condition though. I find it more intuitive to specify a tublence level and a turbulent length scale.
Turbulent viscosity ratio | Balaji | FLUENT | 5 | May 27, 2014 03:47 |
hel (turbulent viscosity ratio limited) for supersonic combustion problem | omar.2002bh | FLUENT | 2 | September 5, 2012 11:04 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
On limiting to turbulent viscosity ratio! | varghese | FLUENT | 2 | November 15, 2003 08:56 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
