Time-averaged velocity for transient flow using UDF or Data sampling |
October 13, 2017, 19:34 |
Hello Everyone,
I'm conducting some research for my Master's project and I'm having some trouble figuring this out. I searched everywhere for a solution but I can't seem to find one. I've only seen one reply but I can't access the UDF they provided (http://www.eureka.im/1104.html) I'd really appreciate it if someone can help me. An example is this: I iterated my case till timestep no. 200, saving files after every 10 timesteps. Now I want to see the average velocity for timesteps 50 to 120. I tried looking at Data sampling, but I couldn't find a place where I can choose from timesteps 50 to 120; or any range of timesteps that is. I would really appreciate any help. Best Wishes, HZ |
October 18, 2017, 11:11 |
Martin
Rep Power: 9 |
Hi HZ,
best way is to define your own monitor points and report files. On the left hand side in "monitors" you can define your own statements/parameters/monitor points for surfaces or volumes like "mass weighted average of velocity @ inlet" similar things. Then you can plot them like the residuals or check to write them to a file in your solution directory... if you have several variables you can create a report file and get them all into one file with values for every time step / iteration and then process them in Matlab or whatever. Of course you need to define this before running the simulation, I do not know if there is an option for getting this data after a calculation similar to what you just tried. Good luck trying. Martin |
average, fluent, time, transient, velocity |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
