Fluent 6.2.16 on cluster saves data files slowly
Old   May 15, 2007, 06:37
Default Fluent 6.2.16 on cluster saves data files slowly
cle3000
Hello! I have following problem regarding Fluent on a cluster. The calculations run fine but when I want to save with the autosave command it takes up to 1 hour to save a 70MB large data file. I also get following message in the command window which I never had before:
"Host receiving summary from compute node zero. Writing "/array/clemens/estonia/empty/deck4_vinlet_poutlet-0001.dat"... Host receiving injections from compute nodes. freeing host particles. Done."
Does anybody know what could cause this slow down? Thanks for any help! C.
Old   May 18, 2007, 06:52
Default Re: Fluent 6.2.16 on cluster saves data files slow
Bogdan
The messages you get on the console are normal, don't be worry about them. Which communicator do you use? try the -pnet option, is not the fastest one in communication, but for writing files in parallel is the best.
Old   May 21, 2007, 09:54
cle3000
Thanks for your help!
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Data Transfer - Polyflow to Fluent to Abaqus Bob Carson FLUENT 0 March 27, 2007 09:31
Tecplot Variable Names For Fluent Data Files Simon FLUENT 0 September 22, 2005 10:44
Structure of case and data files Frederic Nicolas FLUENT 1 August 4, 2000 11:54
Binary files stored by Fluent Jackson FLUENT 1 April 2, 2000 21:58
