New Material
Old   June 8, 2007, 13:59
Default New Material
M.E.
Hi, I'm trying to create a new material to inject in DPM. everytime I create this new material, and enter all the properties, I'm unable to save it, it'll give me an error message..
Any idea why?
Can anybody please give me a brief procedure on how to do it?
your help is greatly appreciated! thx
Old   June 8, 2007, 14:24
Default Re: New Material
Shanti
Could you tell what the error is?
Old   June 8, 2007, 15:07
M.E.
1- Define > Materials 2- User-Defined Database 3- I create a new file 4- New 5- I enter the name, type (droplet-particle), and insert properties 6- when I click apply, i get the following error:
Error: CAR: invalid argument [1]: wrong type [not a pair] Error Object: ()
Error: list-remove: null list Error Object: #f
Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: #f
Old   June 10, 2007, 00:05
zhaoh
1- Define > Materials 2- Fluent Database...3- Fluent Fluid Materials...cope...4 you can change the properties of the materials.Change/Cope...5 Define->Injections...-> select the material of particle which you have dealed with.
Old   June 11, 2007, 09:04
nick
Is it necessary to create the new material in the User-Defined Database? To create a mixture, for example, usually I add the species I need from the Fluid panel, then I select Mixture and, using the Edit button, I add the species I want to be in the mixture, then under Name in the main Material panel I rename it as I want so I can eventually modify mixture and/or species properties.
Old   June 11, 2007, 09:24
Xiana
I use to create first of all one injection with the default parameters (inert particle).Then I go to the material panel, I choose in material type "inert", I write there the desired parameters (name, density...) and save it. normally I overwrite anthracite (the default inert material). But that only works when you are using inert particles!
Xiana
Old   June 11, 2007, 10:06
M.E.
Thank you all for your replies, I tried it and it helps...
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Wall Material Maple FLUENT 4 March 13, 2009 05:39
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
