Target Mass Flow Rate
Old   June 8, 2007, 05:59
Default Target Mass Flow Rate
Brian Tang
Does anyone know if there is any real difference between using a pressure outlet with target mass flow rate specified and using a mass-flow inlet, but with the velocity specified in a direction that takes it out of the domain? As far as I can tell, both will merely adjust the static pressure each iteration to match the targetted mass flux.
Thanks! Brian
Old   June 11, 2007, 09:11
Default Re: Target Mass Flow Rate
Xiana
Hi Brian, I have the same question!!! I donīt know why using a pressure outlet with target mass flow should adjust the static pressure to match the targeted mass flux.I did it and I saw that in the solution the outlet pressure is different as what I defined. What happens exactly in this boundary condition: pressure outlet + target mass flow???
Thank you very much
Xiana
Old   June 20, 2007, 19:05
red lemon
target mass flow rate dynamically adjusts downstream static pressure to meet the summed mass flux specified and the defined pressure is ignored. Fluent doesnt allow negative mass flow inlets (try it) so dont use with negative vector. Negative velocity inlets for outlets are ok for incompressible flow though. Always keep a bc as pressure to prevent overconstraining solution.
Old   June 21, 2007, 02:51
Xiana
Thank you for your advice "red lemon", I will try with negative velocity inlet. I have another problem with the pressure outlet too. I used it without target mass flow and I noticed that the static pressure that Fluent achieved is not exactly what I defined (0 Gauge Pressure). It differs in some punts in a range of -1000 Pa. Does anybody know why?
Kind regards
Xiana
Old   June 21, 2007, 07:11
red lemon
So you are specifying a 0Pa gauge pressure but youre seeing -1kPa. Could be that : - you have reverse flow and static is treated as total - you are reporting total instead of absolute
If target mass flow rate is used though, the pressure condition is ignored as it cannot to conform to both a constant static pressure AND a fixed mass flux. Enabling one disables the other.
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
Regarding Target Mass Flow Rate Ravinder Yerram FLUENT 3 October 22, 2011 07:05
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
Target Mass Flow Rate Tang FLUENT 2 May 13, 2005 11:56
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
