demos version of fluent
Old   June 15, 2007, 00:46
Default demos version of fluent
georges
I'm a french student and now i have a cfd work about flow in pipelines to achieve. I would like to know if it is possible to find a demos version of fluent freely downloadable and if someone could indicate me the link. Thank you very much and sorry if my question is too simple.
Georges
Old   June 15, 2007, 01:15
Default Re: demos version of fluent
Tomasz Bednarz
as for my knowledge there is no such thing as demo version of fluent... but maybe i'm wrong - best way would be to contact directly ansys, good luck
Old   June 15, 2007, 09:07
Phil
Tomasz,
If you download emule from emule project you can search for a pirate version of fluent. This however is illegal so I'm not advising you to do this but know from colleagues that this is how to obtain a free version.
Phil
Old   June 15, 2007, 09:22
Tomasz Bednarz
this is not free version - this is simply copyrights violation...
Old   June 15, 2007, 09:36
Phil
Yes it is copyright violation but lots of people who do very important research find it useful to be able to use fluent on their laptop.
Their funders pay fluent £2500 a year per license and some people then occasionally use their laptop when NOT using the actual license, hence it makes no real difference.
Old   June 15, 2007, 20:11
Will
If they just need to use Fluent on their laptop it's very easy to have the department/company IT service setup a VPN so that you can connect to your license server from anywhere in the world. That's how most people I work with use Fluent away from their office.
Old   June 16, 2007, 08:09
Phil
We can use our own desk pc via internet remote control but I literally don't know anyone who has bothered except one guy who works away at some company.
We can also link our laptop into our Uni system and access the licenses but I know someone who went to get it set up and they wanted to go through his whole laptop with a fine toothcomb so he didn't bother.
If I use my laptop it's only to create a mesh which I do like using my laptop for even in my office.
Old   June 16, 2007, 08:10
Bernard. T
That's how I use to connect to the company license server even if I am in Vietnam (secured connexion to the company servers)
Old   June 16, 2007, 08:11
Bernard. T
Old   June 16, 2007, 08:17
Phil
So whats this VPN then cause that sounds like a good way to access a license without having to be security cleared into the network?
I'll speak to the guy who usually sorts out the IT stuff cause it's only on their licenses I can use the NOx model.
Phil
Old   June 18, 2007, 07:03
  #11
Charles
Mmmm. If you have a security problem (i.e. a problem with the security admin people ...) a VPN is not actually a brilliant solution. The VPN gets you into the network, so if you are a security risk you can still cause problems. A solution that works, but seldom seems to be used, is to set up port-mapping on the corporate network side, so you access the license server port at the firewall's IP address, which is mapped internally to the license port on the license server behind the firewall. It is only necessary to open the license server port numbers on the firewall, and then you can also still restrict access to a user from a known IP. This way the remote user does not get into the network, and can't cause any trouble.
Old   June 18, 2007, 11:38
  #12
Barry Roff
You could try OpenFoam, which is true freeware
Old   June 20, 2007, 03:50
  #13
georges
Thanks for the advise.
prePDF preprocessor in FLUENT (ANSYS 12 version) anee Fluent UDF and Scheme Programming 7 March 18, 2013 22:57
Error swithcing between single e parallel version of fluent bishop_house FLUENT 0 February 28, 2011 12:14
OpenFOAM-1.6 install cookbook MadsR OpenFOAM Installation 372 November 20, 2010 11:57
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 10:57
Fluent Parallel/Serial version..jump in residuals Sandeep Abhyankar FLUENT 4 January 10, 2000 09:57
