time plot
Old   June 14, 2007, 11:13
Default time plot
dan
how to plot/monitor a variable as a function of time in a transient problem? in other words how to plot variable values on the Y axis and time on the X axis? thanks
Old   June 14, 2007, 13:40
Default Re: time plot
bashu
define a point, line or surface go to solve, monitor, surface monitor and define a monitor of that variable on the surface. there are several options you can choose from can do this with volume monitor too.
Old   June 15, 2007, 09:15
dan
thanks, I did create a surface monitor, but how to plot, for example, temperature as function of time and not number of iterations?
Old   June 15, 2007, 11:08
bashu
in the define panel choose flow time instead of iterations
[OpenFOAM] plot temperature vs time in paraview - chtMultiRegionFoam phsieh2005 ParaView 2 March 16, 2014 06:50
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 10:23
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
PLOT TIME vs PRESSURE Parshant Dhand FLUENT 0 January 17, 2003 15:31
