Sawdust Combustion-Non-premixed Combustion Model |
June 16, 2007, 17:35 |
I have 2 questions regarding combustion of sawdust in a furnace. My sawdust burners are located on top of the coal burners in my furnace.
Question 1: from Define -> Models -> Species -> transport&reaction, in the 'Table' tab in Species model, FLUENT asks for 2 temperatures, fuel and Oxid. can anyone advise me what are the 2 values appropriate to my case? The sawdust enters with primary air (at 300K) and hot flue gas from coal burning below is 1300K. Question 2: when I define pdf-mixture material, what are the suitable values for transport properties, ie thermal conductivity and viscosity? Really hope someone can help me with these!! Looking forward for your replies and thank you in advance!! Jessy |
June 19, 2007, 10:59 |
Re: Sawdust Combustion-Non-premixed Combustion Mod
Hi, The appropriate temperature must be judged by the person who have done the experiments. You must be familiar that you are trying to model vapor phase combustion of the fuel.
Oxygen can exist at room temp secondly the properties can be constant to start with. Later if you feel like the the properties are varying much inside the domain. you can either use poly nomial kind of variation or u can use kinetic theory Thandavan |
premixed combustion using Zimont model | bob | FLUENT | 12 | January 9, 2017 13:02 |
Non Premixed Combustion | santhosh1987 | FLUENT | 3 | January 2, 2017 10:42 |
How can I model H2-AIR combustion | popi | CFX | 8 | August 16, 2007 05:32 |
Premixed combustion in Spark Ignition engine | kevin | FLUENT | 1 | June 23, 2006 02:59 |
Need Similar Combustion Tutorial as my model | Arnab | Siemens | 0 | May 24, 2005 18:23 |
