June 25, 2007, 02:43 |
DPM - Why do the particles not vanish?
Hi there,
when simulating the injection of fuel into a combustion chamber, I've got a problem. The particles mass and diameter do not reach zero. The particles size was about 25E-06 m and only reaches about 2.5E-06m. Why is this so? The temperature is high enough and the length of the computational domain should be big enough to let all particles to evaporate. There seems only to happen evaporation at the beginning and then it stops. Another problem is, that the particles minimum temperature does not match my initialization temperature. I initialize the particles with a temperature of 293.15 K into hot air of about 800K. Nevertheless the lowest temperature of the particles in the particle tracking modus are about 370 K. I would be glad, if someone can help me. Greetings, Johannes. |
Injection of specific number of particles in DPM | DH | FLUENT | 12 | March 16, 2016 21:04 |
Constant & independent velocity for DPM particles | Wikie | Fluent UDF and Scheme Programming | 1 | September 23, 2010 05:35 |
Extracting pressure of particles in DPM | teymourj | FLUENT | 0 | June 1, 2010 14:37 |
dpm and size of particles | anissa | FLUENT | 1 | July 20, 2009 13:36 |
DPM - do the particles affect the liquid? | Nikhil Dani | FLUENT | 0 | January 1, 2009 11:58 |
