July 2, 2007, 09:35 |
UDF problem
Hi all, I am new to Fluent,i am solving unsteady stage,the inlet velocity is function of time. is it possible to write the following udf?
#include "udf.h" DEFINE_PROFILE(unsteady_velocity, thread, position) { face_t f; begin_f_loop(f, thread) { real t = RP_Get_Real("flow-time"); if (0<=t && t<=0.72) F_PROFILE(f, thread, position) = (-45.1407*t*t*t*t*t+ 47.2291*t*t*t*t + 11.42*t*t*t - 26.9213*t*t + 8.1241*t + 0.9117); if (0.72<=t && t<=1.44) F_PROFILE(f, thread, position) = (-45.1407*(t-0.72)*(t-0.72)*(t-0.72)*(t-0.72)*(t-0.72)+ 47.2291*(t-0.72)*(t-0.72)*(t-0.72)*(t-0.72) + 11.42*(t-0.72)*(t-0.72)*(t-0.72) - 26.9213*(t-0.72)*(t-0.72) + 8.1241*(t-0.72) + 0.9117); } end_f_loop(f, thread) } Even import successfully into Fluent but it was interrupted while running. the error is: divergence detect in AMG solver:temperature how can i setup the proper parameter like time step and number of time step? Thanks advance in for any reply |
July 2, 2007, 22:09 |
Re: UDF problem
You can have a try...
Run fluent --> open your case..... Solve-->Controls--> limits--> "Temperature range" Good luck, Braket |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
Problem with my udf | july | Fluent UDF and Scheme Programming | 3 | June 20, 2010 06:56 |
UDF problem | mansha goraya | FLUENT | 0 | October 29, 2007 00:31 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 07:14 |
UDF problem | chiseung | FLUENT | 4 | January 10, 2002 09:58 |
