Modelling Biomass Combustion via Species Transport
Like Tree7Likes
Old   July 18, 2007, 10:14
Default Re: Modelling Biomass Combustion via Species Trans
  #21
Kino
Dear Allan,
Now I generally understand how you construct a matrix. For the case of consdering for example CH4, CO2, H2O, H2, CO, NH3, H2S, two additional equations will be required besides 5 elemental balance equations. One of them is based on the data of heating value. Now, my questions are:
(1)for simulation of biomass or coal, how do you determine the ratio of H2O/CO2? Why do you prefer to choosing the relation between H2O and CO2 insead of others? Is it easy to get from experimental findings?
(2) In your calculation, I suppose that the MW of volatiles is assinged directly by you? Am I right?
(3) If I add one product for the volatiles,say Tar, I need an additional equation for balancing. In this case, could you suggest an approach to select one closure relationship?
(4) In addition, I noticed that the volumetric basis (rather than a mass fraction!) is used for moisture fraction in wet combustion. But I aslo noticed that the mass fracton is mentioned t be used in WET combustion (see eq 23.3-27, UG6.2). Now, I am really confusing. What is your opinion on this?
Thank you very much. Kino.
Old   July 19, 2007, 14:42
  #22
Allan Walsh
(1) In my general case, if you set the fractions of CH4 and CO2, the concentrations of the other species will be determined. The assumed fractions of CH4 and CO2 will influence the calculated heating value, so if the heating value is independently known, it provides a guide in the assumptions.
(2) The MW is determined in my calculation, independent of Fluent, and then specified in as a fluid property.
(3) Your tar would have some composition (say C7H8O like cresol) which would have to be accounted for in the mass and energy balance. I may not have made it clear, but this approach is to generate a volatile gas that is consistent with the biomass fuel composition. Since there are more unknowns than equations, there is more than one possible combination.
Also, the approach (which I have used) in determining the volatiles composition ahead of time can't account for differences in the products - say as a function of local temperatures. You may want to change the tar fraction if the heat flux is low, for example. To do this takes extra steps.
(4) My opinion on the moisture fraction is that it has to be verified in each case. If you are modeling 10 kg/s of fuel and it is 25% moisture by mass, then there better be 2.5 kg/s of water showing up. The cases where the definition (mass or volume) becomes a problem is when the particle density is not constant. You can try this out for yourself.
Old   July 19, 2007, 19:44
  #23
Kino
Dear Allan Walsh,
I still do not exactly understand your answer (1). Maybe, our calculation steps are different. My calculation steps are as follows1)By means of the data of HHV,proximate and ultimate analysis of biomass, the elemental compositions and formation enthalpy for the volatile is calculated firstly; (2) then, I would like to decompose the volatile into CH4,CO,CO2,H2,H2O,tar. Because of step 1, the information of HHV ( or formation enthalpy,alternatively)of the volatile has already been used in my case. Therefore, the problem in this step now turns: How to use just three elemental blance equation (C,H,O) to determine 6 coefficients for CH4,CO,CO2,H2,H2O,tar? Even not considering tar, two additional equations are needed.
At present,I am actually in trouble of choosing the effective relationship or correlations to close all the equations. Especially for biomass prolysis/devolatilzation,how to select out these relations?could you please help me out? Thanks in advance!
Old   July 20, 2007, 00:40
  #24
Racheal
Can someone tell me if I have done the above calculations correctly? Hoping for replies, thank you very much!
Old   July 26, 2007, 12:38
  #25
majid
i cant define tow or more udf .
Old   October 20, 2009, 21:48
Question Issues with Steam gasification
  #26
Elango
elango86 is on a distinguished road
Fluent inherently has a mixture type for woody-volatiles ,that cud be combusted with air.But i would like to do the modeling by gasifying the wood chips with high temperature steam instead of air.
I am having problems with defining the wood chips in the global equation and determining the number of reactions required for modeling since, the product gas composition includes H2,CO,CO2,H2O,CH4
elango86 is offline   Reply With Quote
Old   March 4, 2014, 22:22
Default modelling species-porous zone-
  #27
Hassan Khodaei
hnkhodaie is on a distinguished road
Dear Allan,
Many thanks for good information regarding to modelling species in biomass combustion.
I am trying to create a fixed bed model combustion in Ansys-Fluent 14.5 using porous zone part.I want to apply 12 kw heat flux at the top of the bed (porous media) and study moisture evaporation and volatile released from densified wood pellets which are used in our experimental investigation ( A 20 cm cylendrical fixed bed combustor). Do you think, is it possible to model species by porous zone in fluent or not? If Not is there any other suggestion for modelling fixed bed in Fluent? Do I need writing UDF for modelling moisture evaporation and devolatilisation or the available models in fluent could be responsible to my requirements?
Kind Regards,
Hassan Khodaei.
hnkhodaie is offline   Reply With Quote
Old   April 28, 2016, 06:19
Default CFD modeling of wood pellet combustion
  #28
iam
iam is on a distinguished road
Hi all,
This is a post from a few years, but I am experiencing similar doubts at the moment, and I was wondering if someone could help.
I am trying to simulate with Fluent the combustion of wood pellets, At the moment I am using the wood-air model provided by Fluent. Could someone help me to calculate a good molecular weight and heat of formation of the volatiles? I have the elementary analysis of the wood pellets and the burning rate and I would like to estimate the molecular weight and heat of formation from those values.
Once I am done with this calculation, I would like to move on an use a more detailed reaction mechanism for my calculations. I already have a reduced mechanism, but I am not sure how I could estimate the composition of the initial volatile gases from the elementary composition of the pellets (C,H,O,N,S).
Thanks a lot for your help!!!!
iam is offline   Reply With Quote
Old   October 13, 2016, 10:39
Default biomass
  #29
nadia
adna is on a distinguished road
hello every body
me also I try to simulate biomass combustion especially ollivewaste,but i don't find it with material's pannel so i choose to work with empirical formula in non premixed combustion and i don't know how to do in discret phase model,tell me if i'm on the right way,if anyone work on this and can help me
adna is offline   Reply With Quote
Old   June 17, 2017, 00:04
Default how to balance the biomass gasification
  #30
rahul gupta
rahulgupta is on a distinguished road
i work on gasification of biomass in downdraft gasifier using species transport model.i got the empirical formula of biomass using coal calculator , C1H1.26O0.6N0.014.
i want to use reaction
C1H1.26O0.6N0.014---> XCO+YC02+ZCH4+Wh2
give me suggestion for how to find the value of x, y ,z, and w
rahulgupta is offline   Reply With Quote
Old   November 4, 2017, 23:37
Default Difference between species transport and non premixed combustion model
  #31
Anirudh Singh
ani4377 is on a distinguished road
Dear all,
I have to simulate a gasifier combustion which is using rice husk and and sand fluidised bed. Do I need to do multiphase. I am trying to do by non premixed combustion model.
I am confused a lot.
Can anyone tell me when to use species transport and when to use non premixed combustion. It will be a great help guys.
ani4377 is offline   Reply With Quote
Old   November 4, 2017, 23:41
Anirudh Singh
I have found a video on youtube and you can search simply as "Discrete phase simulation on it". I am also simulating almost same problem. In non premixed model you can add your own fuel by knowing the composition. We cannot do this in species transport. But most of papers on combustion simulation use species transport . If you find anything , please reply.
Old   November 7, 2017, 16:23
Hassan Khodaei
Hi Ani,
If you are going to simulate solid particle such as fludized bed reactor modelling (or granular) you need to use multiphase (granular-Euler-Euler) approach. If you want JUST to simulate syngas you need to use primixed(if your syngas is with air), non premixed (if you have separate air and fuel inlet) or partially (if you have both mixed syngas and/or separate burner (propane etc.).
Old   November 7, 2017, 16:27
Hassan Khodaei
Hello All,
The following attachment is the UDF for evaporation in single biomass particle.
Old   November 8, 2017, 02:21
Anirudh Singh
Thank You dear.
One more thing ....what is the difference between species transport and non premixed combustion.
Old   November 23, 2018, 23:31
Anshuman Sinha
Anshs is on a distinguished road
Hey Rachael ! can you send me your file ! I want to learn how you are coupling 3 reactions together?
Thanks
Anshuman
Anshs is offline   Reply With Quote
Old   April 1, 2019, 07:05
Default Need help to run calculations
  #37
Manoj
mkatwe is on a distinguished road
Hi all,
I am working on similar project at the moment, and I was request if someone could help.
I am trying to simulate with Fluent the combustion of wood logs (30mm X 30mm X 100MM Long) , At the moment I am using the wood-air model provided by Fluent.
After I run the simulation for ~2000 iteration, still the temp is not rising.
Can anybody please provide me wood burning fluent file so that I can learn & can modifiy as per requirement ?
mkatwe is offline   Reply With Quote
Old   November 9, 2019, 01:33
Anirudh Singh
Dear Allen,
In fluent I am unable to add Cl in the ultimate analysis in coal calculator. There is only C,H,N,O, and S in UA but not Cl.
Can you please tell me how to add it.
Its urgent for me and i ll be thankful if you reply asap.
Thank you
Old   July 4, 2021, 05:48
Dr.Sharad Pachpute
pachputesharad is on a distinguished road
CFD Modeling of Biomass comprises devolatilization, char combustion. It is problem of multiphase turbulent combustion modeling, visit this page on it: https://cfdflowengineering.com/turbu...se-combustion/
Coal combustion problem is similar to this bio gas problem for fuel composition, species (volatile matter, fixed carbon, ash etc.) and chemical kinetics
pachputesharad is offline   Reply With Quote
Old   January 8, 2022, 07:42
Maharashtra
surajghiwe is on a distinguished road
Hello everyone I am trying to simulate the solid biomass combustion using fluent but not sure which species model to use (species transport or non-premixed model). again is it compulsory to use a discrete phase model cause in my case my fuel inlet is in a solid form not in particle form?
Thanks
Suraj
surajghiwe is offline   Reply With Quote
Combustion Chamber Species Transport Catthan FLUENT 2 April 27, 2021 03:39
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
Please help!! Patch and Species transport Julie FLUENT 5 August 3, 2016 03:10
Species transport combustion model hari FLUENT 0 October 26, 2007 02:18
the equation of species transport for combustion Arman FLUENT 1 October 17, 2007 06:43
