Skewness & Decomposition
Old   July 5, 2007, 09:38
Default Skewness & Decomposition
Marc
Unknowingly, I've been running simulations where a low number of elements in a VERY complicated flow region have very high skewness. Unfortunately, I only realized this well into processing my simulations.
I have since attempted to replace the very tight corners which were causing the skewness. However, this has made it practically impossible to make use of a rectilinear mesh.
Aside from changing the geometry, are there other approaches that can be used to fix skewness?
Thanks in advance.
Old   July 5, 2007, 12:12
Default Re: Skewness & Decomposition
SV
If you are using Fluent 6.3, trying making polyhedra from the skewed cells to reduce the skewness. This helps most of the time.
Old   July 5, 2007, 14:54
Marc
Not sure I completely understand. Should I redesign the entire face that's a problem? I am unfamiliar with how to manipulate the actual cells (aside from very cumbersome methods) in the way you mention.
Thanks for the help so far.
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
TGrid High Skewness khimkhim ANSYS Meshing & Geometry 1 February 17, 2010 23:36
problem with skewness jjchristophe FLUENT 1 January 14, 2010 21:22
Severe nonorthogonality and severe skewness problem qtian OpenFOAM Running, Solving & CFD 2 January 22, 2008 18:47
Skewness Taskin FLUENT 5 April 6, 2005 15:21
