Internal flow simulation boundary conditions
Old   July 2, 2007, 02:12
Default Internal flow simulation boundary conditions
Kishore
hi, need ur suggestions in this prblm Problem description: it is a internal flow simulation through a duct connected to a chamber which has 2 outlets(identical area).the flow is a velocity at inlet is 42 m/s and static pressure is 1.2 bar with T= 298 k. outlet conditions are not known. pressure drop from inlet to outlets is not known.
method i tried for simulating and getting conditions at outlet is as follows : i gave velocity inlet and 2 outflows and computed the static pressure using area weighted average option for the two outlets. then in the second simulation i gave this static pressure at outlet and 1.2 bar at inlet with pressure inlet and pressure outlet boundary conditions. my query: is this simulation physically correct to determine the outlet conditions? because when initializing before iterating , the inlet velocity which fluent computes and gives for initialization is nearly 3 times (150 m/s). kindly help in this...
Old   July 10, 2007, 11:42
Default Initialization with UDF
Chx
Using FLUENT, I am trying to generate a regular wave in a 2d domain by specifying a transient velocity profile at my inlet. The top and end of my domain are pressure outlets with atmospheric pressure and hydrostatic pressure specified for both boundaries respectively. Gravity is acting in the negetive y direction and based on my UDF, I expect maximum velocities of 1.7m/s but when initializing before iterating , the inlet velocity which fluent computes and gives for initialization is nearly 17 times (28 m/s). I have looked at and had many guys look at my UDF over and over again and can't find anything wrong with it. Any body has an idea where the problem could be?
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 05:35
Periodic boundary conditions in 3D Eulerian granular flow simulations dsm FLUENT 4 March 2, 2012 19:04
Boundary conditions low Mach number flow lost.identity Main CFD Forum 0 November 28, 2010 04:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
