Mixing of two different fluids in a swirl
Old   July 9, 2007, 01:34
Default Mixing of two different fluids in a swirl
AK
Hi Everyone.
I am trying to analyze the mixing of two different fluids entering tangentially into a cylindrical mixing chamber. I am using velocity inlet BC for both entrances. The chamber has one outlet and it has pressure outlet BC imposed on it. The model is three dimensional and I would like to keep it that way(For comparison with literature available to me). The flow is laminar and there is no reaction between the two fluids.
Can someone tell me how should I proceed with it?
Thank you.
AK
Old   July 9, 2007, 01:43
Default Re: Mixing of two different fluids in a swirl
mayur
depends on whether u r using a steady state or transient analysis?
Old   July 9, 2007, 01:57
mayur
u can use VOF or the mixture model... I assume that the fluids r immiscible.
Old   July 11, 2007, 07:32
Phil
If your fluids aren't different phases you should just use the basic species transport equations.
For fuel air mixing writing a udf to plot the equivalence ratio tells you if the mixing is correct.
Remember for swirling flows you need to increase the cell density towards the centreline. You should also use a structured grid in the important downstream area.
Phil
PS- you should let us know more about your problem.
two mixing compresible fluids solver ziemowitzima OpenFOAM Running, Solving & CFD 27 August 13, 2020 12:40
Mixing Station with high swirl AleDR FLUENT 23 November 5, 2009 11:49
2 diferent fluids mixing Figd84 FLUENT 12 October 2, 2009 02:24
FIDAP-Properties Definition in Fluids Mixing Area Q. Hao FLUENT 0 February 17, 2005 12:00
turbulent mixing of two fluids ulrich bieder Main CFD Forum 2 October 9, 1999 16:15
