FLUENT Supersonic Combustion
Old   July 13, 2007, 10:56
Default FLUENT Supersonic Combustion
Alexandre Neophytou
Hello, I am modelling Supersonic Combstion with Fluent.
I started with a 2d case Coupled Implicit solver, and every thing was pretty fine. The CFL number had to remain under 1 though ( slow convergence, anyway).
Now I try to do the same with a 3d calculation,it is VERY Slow. I am currently computing a mixing case. What should I do. Is it a problem linked to Couple or Implicit solver?
Old   July 17, 2007, 01:38
Default Re: FLUENT Supersonic Combustion
gopal
yes it is!try changing the courant number(incresing) for every set of time steps after the solution got stabilised.
supersonic combustion in Fluent argeus FLUENT 2 April 2, 2023 06:39
Assistance for modelling unsteady supersonic flow in FLUENT SATISH A.V FLUENT 11 October 1, 2014 22:36
combustion of particle in fluent Devy FLUENT 0 March 13, 2003 05:12
Can I use Fluent to stimulate diesel combustion Allanhill FLUENT 1 March 6, 2003 07:46
which combustion model can be in supersonic field cfdfans FLUENT 0 March 9, 2001 22:13
