Skewed mesh simulations
Old   September 2, 2007, 01:22
Default Skewed mesh simulations
Christopher Peacock
I could really use some advice on running simulations on a mesh that features skewed elements. I have ~3million elements in a tetrahedral mesh, of which 15 are highly skewed (>0.98). I can't run a simulation without converting these to polyhedra. But the simulation continually breaks down after ~30iterations and I have serious doubts about the solution accuracy. I am now running a laminar flow at reduced under-relaxation factor and courant number just to get anywhere with the simulation. I have serious doubts about the this approach as well.
Cheers, any help would be appreciated!
Chris Peacock
Old   September 3, 2007, 01:43
Default Re: Skewed mesh simulations
mAx
forget your solution with such high skewed cells. Try to get max high skewed cells around 0.9 (max. 0.95)
Old   September 3, 2007, 07:06
AAA
Try adaption of grid equiangle skewness and set maximum value.
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Other] vtk mesh or Abaqus mesh to OpenFOAM bigphil OpenFOAM Meshing & Mesh Conversion 27 November 23, 2015 17:31
Skewed hexahedral mesh in LES gascortado OpenFOAM 0 March 22, 2011 12:10
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
