compressible flow
Old   September 5, 2007, 17:59
Default compressible flow
maria teresa
im working on a simulation of axial compressor passage, and im having problems using the compressible flow.
which are the caracteristics i have to use in problems with moving frames if a want to use compressible flow?
i tried with segregated model, because fluent recomend this, and k-epsilon turbulence, because it has a small mach number, but neither of those are used in the tutorial of compressible flow. i also put the velocity formulation relative, and if i used the coupled model i canŽ´t do this, and fluent recomend this velocity formution.
when i did my first iteration it gave an error with the flowting point, i i check the mesh and itŽ´s ok, then i tried it whitouth the compressible flow and it run.
i donŽ´t know if the operative pressure may be an issue, iŽ´m using the default one.
i also check all the boundary conditions with moving frames and the problem presented when i treid to do it whit wall speed
i donŽ´t know what im doing wrong
thank in advance
Old   September 7, 2007, 16:58
Default Re: compressible flow
JAI SHANKAR V P[
I AM JAI SHANKAR V P . I AM CURRENTLY WORKING AS SENIOR LECTURER WITH SNMIMT IN INDIA .I AM CURRENTLY COMPLEATING MY MASTERS IN PRODUCTION ENGINEERING WITH COCHIN UNIVERSITY OF SCIEANCE AND TECHNOLOGY , KOCHI, KERALA , INDIA
I AM VERY MUCH INTRESTED IN THE SUBJECT CFD
CAN YOU HELP[ ME STUDY THE SAME PLEASE MY EMAIL ID IS shankarvp@yahoo.co.in
with regards
jvp
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Natural Convection using Compressible Flow (chtMultiRegionFOAM) msarkar OpenFOAM 2 September 7, 2010 00:13
help with compressible flow BC's (need subsonic flow) meangreen Main CFD Forum 5 July 24, 2010 13:16
Compressible Fluid Flow in COMSOL Multiphysics BBG COMSOL 1 November 19, 2008 14:05
Solving unsteady compressible low speed flow atit Main CFD Forum 8 July 31, 2000 13:19
