September 12, 2007, 17:28 |
non-positive-volume
hi all,
what cann i do when fluent say that i have a non-positive-volume??? thanks! |
September 13, 2007, 05:39 |
Re: non-positive-volume
Within fluent, nothin much, try Check grid or smooth/swap otherwise redo your mesh in your mesh generator. Often a smoothing there is enough.
September 14, 2007, 06:33 |
In the gambit volumes panel, check volumes for both geometry and topology. In the results if you find any volume that failed - thats would the problematic volume.
If this fails make sure that there are no faces with very small areas from the tools panel. Even then if you still see a non-positive volume, try reading it in fluent 3ddp instead of 3d |
September 15, 2007, 02:24 |
thanks very much !
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
