October 1, 2007, 05:02 |
Edges in Gambit
I am having trouble creating a 3D geometry. I have a circular face composed of several edges for various reasons. When I transform this into a cylindrical volume by either sweeping face along an edge or stitching faces together I no longer keep the original edges when viewed. I mean when viewing from a top down view which is essentially a 2D view, I should not see anything except the top circular face of the cylinder. But I am seeing the bottom circular face too, and it's edges seem a bit off from the top face. Why aren't the edges of the top and bottom face alignes as they should be? Thanks |
October 2, 2007, 09:19 |
Re: Edges in Gambit
Only reason I can figure, is that the line(edge) you are sweeping along isn't perpendicular to the circular face(bottom face).
BR Kasper |
October 2, 2007, 09:53 |
Re: Edges in Gambit
u mean after sweeping , u get an offset . ok may be u should try to translate the edges of your first circular face separately and then join each of them separately . Do you understand what i mean ?.
October 3, 2007, 06:36 |
Re: Edges in Gambit
I think I understand. You mean copy and translate the edges, then either making a volume of the wireframe or make faces then stitch them together, is that right?
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Strange error in Gambit while meshing edges | Ilu | ANSYS Meshing & Geometry | 1 | July 16, 2010 08:17 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Deleting Edges in Gambit | Alberto Schroth | FLUENT | 4 | May 31, 2000 14:15 |
